Nosewheel Steering
Nosewheel Steering
I have a question regarding the operation of the tiller. Assuming that the Captain's tiller is moved back to turn left and forward to turn right (it may be the opposite!). Does the Co-Pilot's tiller work the same way or does it work in an opposite manner? ie. If my surmise is correct would the CP's tiller move back to turn right and forward to turn left?
Re: Nosewheel Steering
Hi
aircraft controls are designed to be 'instinctive' as in - they move as your brain expects them to. The co-pilots nose wheel steering is in fact NOT a mirror as you assumed. That is looking at the tiller it is left movement to turn left and right for right
hope that helps
hope that helps
Thanks Murray,Murray Keene wrote:Hi
hope that helps
That's what I expected!
The two tillers are connected. The captains was "direct" to the nose wheel whereas the copilots was a wire that went to the captains tiller so there was a bit of play in the system. If you really needed to turn tight, it was better to use the captains (though quite often you would both push on the tiller!).
No worries Andys the expert as hes a driver Im just a spanner man
That must have been fun if there was confusion over whether to turn left or right. I notice also that there's a "stick" behind the tiller. Did that have any part to play?Tonkenna wrote:The two tillers are connected. The captains was "direct" to the nose wheel whereas the copilots was a wire that went to the captains tiller so there was a bit of play in the system. If you really needed to turn tight, it was better to use the captains (though quite often you would both push on the tiller!).
- EGDGZTCW
The stick behind is the support for the cup tray, which slides out along the side the DV window and is stowed against the top of the instrument panel combing when not in use.
... and that cup tray was probably the most important thing on the flight deck!
As for confusion... no. Who ever was driving may ask for assistance but they were always in control.
THE most important thing on the flight deck! The food and drinks tray!EGDGZTCW wrote:The stick behind is the support for the cup tray, which slides out along the side the DV window and is stowed against the top of the instrument panel combing when not in use.
I've often wondered how the sliding cup tray was supported. I totally concur that it's the most important piece of equipment on the flight deck. A malfunctioning cup tray would surely be a no go item
thats definitely an RTB and abort mission with no Tea
Ive attached a couple of system diagrams to show how the steering controls are connected.
Also unlike many modern aircraft, the VC10 steering was free to castor, which meant it could be towed with the hydraulics still pressurised to the leg. any modern aircraft required a safety device to be fitted to remove hydraulics to the steering during towing operations
The tea table slides aft over the rail and then folds down. While folding down the support engages a slot on the underside of the table which supports it in the 'active mode'.
I don't seem to have a photo of the table in use unfortunately...
Excellent diagrams. Many thanks. Was there any speed limit to using the tiller? Or because as you say the nosewheel was free to castor would using the tiller at high speed have a detrimental affect?bobisqueen wrote:Ive attached a couple of system diagrams to show how the steering controls are connected.
Nice image Jelle, Thanks.Jelle Hieminga wrote:The tea table slides aft over the rail and then folds down. While folding down the support engages a slot on the underside of the table which supports it in the 'active mode'.
