Dunsfold fast taxi
Dunsfold fast taxi
Hi
I had a really enjoyable time at Dunsfold a few weeks ago and I've just been shown a really excellent video of it.
During the video I noticed that only two of the throttles were advanced to maximum while the remaining two were only pushed forward a little during the high speed abort. Can someone tell me the reason for this? I'm sure there is a perfectly good reason but just wondered.
Best wishes
Jon
Best wishes
Jon
- 1103
Re: Dunsfold fast taxi
Hi Jon,
There are a couple of reasons.
1. Compared to Brunty Dunsfold's runway is short so we can't apply the power for too long before we have to start applying the brakes.
2. Last year we found by applying power to all 4 engines meant that by the time we reached the start of the crowd line we had reached our speed limit and had to throttle back. By only powering up two engines to full power the acceleration is slower so the crowd get the noise & power for a longer distance along the crowd line.
I hope that answers you question. If you have other questions please feel free to ask.
Paul
Paul
Many thanks for the reply. What do you mean by compered to Brunty, I'm not sure what your refering to?
- 1103
Hi Jon - I was alluding to the fact Brunty has a much longer runway than Dunsfold which enables the 241 group to give 241 more welly for longer on their high speed runs and they don't have to apply the brakes so heavily afterwards, thus reducing the risk of the brakes overheating.
Brunty = Bruntingthorpe Airfield.
Yes, after reading some of the material on this website I now realise there is another intact airframe at Bruntingthorpe. I now know what 1103 meant by Brunty.
Indeed. Bruntingthorpe's runway is effectively a 9000ft (almost 3km) unrestricted strip. Even at higher speeds (60-80kts if the wind is favourable) the brakes are only needed approaching taxi speed.1103 wrote:Hi Jon - I was alluding to the fact Brunty has a much longer runway than Dunsfold which enables the 241 group to give 241 more welly for longer on their high speed runs and they don't have to apply the brakes so heavily afterwards, thus reducing the risk of the brakes overheating.
Thank you for the reply. Makes sense to save on wear and tear.
Do you routinely achieve 80kts during a high speed abort?
Not regularly, but it isn't unusual if the conditions are right.jonpainter wrote:Thank you for the reply. Makes sense to save on wear and tear.
It's also worth noting it's not an "abort" as such. To most pilots that means stopping the aeroplane as quickly as possible (reversers, brakes etc). It's a controlled slow deceleration mainly using reverse thrust to minimise wear on the brakes and the maximum speed is always pre-briefed before the run dependent on conditions on the day.
Keeping the speed at 80kts and below keeps it easier as the aircraft is still controlled using the tiller and "the lifting surfaces" aren't really that effective yet (in service the handling pilot would steer using the tiller/nosewheel up to 80kts, then use the rudder pedals/rudder thereafter)!
Thanks Charlie
Is there anything else that you do differently now to what you would have done while she was in service?
It must be really good to be involved in the preservation of these magnificent aircraft.
Jon
Jon
Not too much - although we don't have a navigator to read out the checklists!jonpainter wrote:Thanks Charlie
Jon
How many people does it take to keep an aircraft like this alive and well? I presume you are all somehow connected to the aircraft?
A reasonable number! It's a mix of former aircrew, former ground crew and an eclectic range of enthusiasts each with a different connection or affection for the VC10 who relish the opportunity to get hands on with such a beautiful aircraft.jonpainter wrote:How many people does it take to keep an aircraft like this alive and well? I presume you are all somehow connected to the aircraft?
Are you talking 20 people? How did you come to be involved in such a project? I only recently found out about these beautiful aircraft being preserved after a trip to Wings and Wheels and it was there one of the guides told me about this website. Its interesting to hear from those that take their time to preserve the aircraft.Charlie wrote:A reasonable number! It's a mix of former aircrew, former ground crew and an eclectic range of enthusiasts each with a different connection or affection for the VC10 who relish the opportunity to get hands on with such a beautiful aircraft.jonpainter wrote:How many people does it take to keep an aircraft like this alive and well? I presume you are all somehow connected to the aircraft?
What sort of maintenance do you carry out? Again does it differ much from what would have been carried while the aircraft was active?
Around that ballpark. I'm former aircrew which is how I came to be involved.jonpainter wrote:
I'll let a better qualified person answer that. Basically the aircraft is kept as serviceable as possible within the resources available. If there are snags, we fix them. I'm sure Dunsfold do the same (being very aware of thread creep!).What sort of maintenance do you carry out? Again does it differ much from what would have been carried while the aircraft was active?
