Avionics
Posted: Fri Nov 03, 2017 12:25 pm
by vololiberista
Assuming the APU is not available would the avionics come on if just ground power was available or only when the generators are running?
Re: Avionics
Posted: Fri Nov 10, 2017 2:32 pm
That depends on the Ground Power switch. With this set to CLOSE, the Ground Power Breaker closes, which connects the Ground Power busbar to the Sys A synchronising busbar, and through the SSB to the Sys B synchronising busbar. In that case power is available for the complete electrical system and thus for the avionics. If the Ground Power switch is left in OPEN position, only 28V DC and domestic busbars are powered, so no avionics in that case. All this is based on the VC10 C Mk 1 pilot's notes - technical, I hope I got it right
Re: Avionics
Posted: Fri Nov 10, 2017 5:28 pm
by vololiberista
Jelle Hieminga wrote: ↑Fri Nov 10, 2017 2:32 pm
Thanks Jelle,
That sounds right. Programming the logic of the electrics panel is a bit of a nightmare. Manged today to get the standy TRU to twitch each time you movethe selector switch. Works nicely.
Re: Avionics
Posted: Thu Nov 23, 2017 8:05 pm
by 1103
The same process applies if the APU generator is available.
