St Athan - the second home?
Laurieg
Normally, here at St. Athan we only see the VC 10 on flight tests or deliveries. These are normally limited to the straight in approach and take-off, for obvious reasons. We have noticed that, although it is only the odd occasion, we appear to be seeing the multiple overshoot occurring. This was normally an isolated incident. We know that Javelin has been signed and we will be seeing the kite here for quite a few years to come so are the RAF training crews up on the approach procedures and so we will be seeing more of this training? (It makes a good diversion from being a hanger rat and the Conway sounds a damn sight better than a RB 199 or Adour)
Never had a GE's wallet. It was always empty when I got back but I always had a smile on my face
- Tonkenna
Speedbird1
Laurieg
St. Athan - second home
I know what you mean. We have TWO here now
808 should be leaving soon and 807 got here today so watch out.
Laurieg
Could be, the a/c still has the pods fitted, as well as the engines. 807 did arrive in a primer finish, though.
Strange seeing the aircraft in the nude
. I took 103 down to Heathrow, BA, to be stripped and sprayed some years back. They took it right down to the bare metal and you could see the original milling marks from the fuselage and wing planks. After the spray you could just feel the rivets etc under a smooth paint job, all filler removed. It was quite a sight when it came out. The BA ground crews were all over it. (Probably did their basic training on it)!!!!!
