Something funny for all you pilots
Post by Murray Keene »
After every flight, Qantas pilots fill out a form, called a "gripe sheet,"
which tells mechanics about problems with the aircraft. The mechanics
correct the problems; document their repairs on the form, and then pilots
review the gripe sheets before the next flight. Never let it be said that
ground crews lack a sense of humour.
Here are some actual maintenance complaints submitted by Qantas' pilots
(marked with a P) and the solutions recorded (marked with an S) by
maintenance engineers.
By the way, Qantas is the only major airline that has never had an
accident.
P: Left inside main tire almost needs replacement.
S: Almost replaced left inside main tire.
P: Test flight OK, except auto-land very rough.
S: Auto-land not installed on this aircraft.
P: Something loose in cockpit.
S: Something tightened in cockpit.
P: Dead bugs on windshield.
S: Live bugs on back-order.
P: Autopilot in altitude-hold mode produces a 200 fee t per minute descent.
S: Cannot reproduce problem on ground.
P: Evidence of leak on right main landing gear.
S: Evidence removed.
P: DME volume unbelievably loud.
S: DME volume set to more believable level.
P: Friction locks cause throttle levers to stick.
S: That's what they're for.
P: IFF inoperative.
S: IFF always inoperative in OFF mode.
P: Suspected crack in windshield.
S: Suspect you're right.
P: Number 3 engine missing.
S: Engine found on right wing after brief search
P: Aircraft handles funny.
S: Aircraft warned to straighten up, fly right, and be serious.
P: Target radar hums.
S: Reprogrammed target radar with lyrics.
P: Mouse in cockpit.
S: Cat installed.
P. Noise coming from under instrument panel. Sounds like a midget pounding on something with a hammer.
S: Took hammer away from midget.
